ricoh mp6500 throut out developer, urgent
  • hsh6049
    • Jul 2012
    • 64
    after replace new developer (type 21) to my ricoh mp6500 developer with proper setting and adjustment , after more than 200 over copies i found out the developer was gone. the toner recyling unit was full of developer. can someone give opinion
    thanks a lot
    • 37488
    Re: ricoh mp6500 throut out developer, urgent
    thanks a lot
    You have posted two posts with the same title. The only difference is the type of developer. Which one is correct?
    • hsh6049
      • Jul 2012
      • 64
      i have two units MP6500, and previous using type18. the other one is type 21. i just want to make sure which one is more suitable
      • pocket aces
        Ricoh Technician
        • Nov 2008
        • 72
        Should't you be using developer type 24?
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          Paul@justmanuals.com
          • katash
            • May 2010
            • 221
            SPOT ON!
            • Ronan
              • Aug 2011
              • 55
              checks the cutting blade of the developing unit or developer entered into the magnet. in the case of type 21. anything let me know how you did
              • Eric1968
                • 2458
                The only one suitable is Type 24!
                If my memory serves me right, Type 18 is for the Aficio 1018, which is a completely different machine.
                • Herostrat
                  • Oct 2012
                  • 220
                  I'd say it's some problem with charge corona/bias electronics...it overcharges the drum and he starts taking out developer along with toner,inspect both developing assembly and drum unit,look if charge corona is cowered in toner/developer,and what type of toner do you use?
                  What are the values of Vsp,Vsg...voltage on charge corona and so on?
                  I know about using type 21 dev in theese machines instead of type 24 but one has to poar in lower amount of dev 21,I allso know about problems it makes sometimes,too much toner in recycling system,too strong toner density on paper that makes problems in fusing assembly.
                  There is a reason for Ricoh to use developer type 24 in those machines...it may be unclear to us but who are we to say that we are smarter?
                  Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
