Ricoh 5510l error 0302
  • acsolutions
    • Jun 2010
    • 519
    [Error Code] Ricoh 5510l error 0302
    Hello, just wondering what this error is and how do I clear it? Thanks
    • 37488
    Re: Ricoh 5510l error 0302
    The 5510L is actually a FAX machine. If the error code 0302 is actually 3-02 (SG3 responce error), then you may have to replace the SG3 board or the FCU. If it is actually SC 302, replace the PCU. It has been a while since I have had to work on these but I seem to remember that they do display a 0 instead of SC before the service code number.
    You might also post to the Printer & Fax forum.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • acsolutions
        • Jun 2010
        • 519
        thanks,for the response. I found it was an alarm code that was an hvt issue. On the drum unit the charge roller was out of position due a broken retainer clip, replaced the drum unit, problem fixed.
