Ricoh MP 25/3350 Ricoh Side Cover (Duplex) Part List.
  • xlbizs
    • Jun 2009
    • 66
    Dear All, My customer have broken one of the Duplexing part at the side cover. Now cant make 2 sided printing/copying.
    we can't find the Duplex part at the part manual. Anyone can help on this and we need to order the part to repair the MP3350. thank
  • joshuadenmark
    Re: Ricoh MP 25/3350 Ricoh Side Cover (Duplex) Part List.
    p_ad3000.pdf
    Hope this is the correct manual.
    • petee7364
      • Jun 2013
      • 7
      the product code for the duplex unit is D369. i can email you a partc catalog if needed or describe part and i can try to grt you a part number. my email is petee7364@yahoo.com
      • joshuadenmark
        Posted above
        • xlbizs
          • Jun 2009
          • 66
          Thank Joshuadenmark,
          This is the one, my customer broken this part (D369 4664 Lower Gate Pawl), Now we can order with the part number. thank a lot .
          Tian
          • joshuadenmark
            Hi Tian
            Glad I could help.
            Nice day to You.
            • TonerMunkeh
              Professional Moron
              • 3865
              Here's a tip, thoughtfully provided to me by spaceman99.
              Where the driven guide plate clips into the duplex door, there is a metal pin the plate locks in to. Add a small piece of Apollon toner pump tube onto this pin and it will clamp the guide plate in place more securely. A common cause of this 4664 gate pawl being broken is the guide plate falling open when the duplex door is opened to clear a jam. The actuator on the gate pawl hits the front fuser pressure lever and breaks off. This mod stops this.
              Hit it.
              • Ivica
                • Mar 2013
                • 1
                you need just this two if your costumer just broke the gate pawl - D369 4664 Lower Gate Pawl ;if you cannot find the spring this is the part number for the spring - AA06 6314 Gate Pawl Lower Spring ;
                and if the hole holder is broken you need this to - D369 4663 Guide Plate - Open/Close .
