richo 3235c makes whole page BLUE
  • mobeus
    • Jul 2025
    when I print black and white the pages looks fine
    when I try and print any document with colour on, the first page has a slight blue tinge but as the document goes on the pages get more and more blue.
    What is going on, this problem just started happening and then has got progressively worse?
    Thanks for any help
    M
  • joshuadenmark
    Re: richo 3235c makes whole page BLUE
    It is the cyan pcu failing, try switching it with the yellow to se if you get the error in yellow instead.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • khaled_abosere3@yahoo.com
        Head technical support
        • Mar 2012
        • 171
        All you can do is to clean the charge roller,cleaning blade and toner waste skewer with housing of cyan pcu.
        • joshuadenmark
          Or replace faulty pcu
            • Mar 2012
            • 171
            I faced the same problem with newly cyan pcu then after 2 weeks the test pattern was with whole page blue I offered this solution for my same case.
            • Eric1968
              • 2458
              Thanks for any help
              M
              PCU's and DV-Units last for 60k. Check the PM counters for PCU's and DV-Units.
              • Llama God
                • Mar 2009
                • 1353
                Dev units do 100k, don't they?
                  • 37491
                  If they have less than 60K, you can get away with cleaning the charge roller. If not, you can clean it and then order a new PCU. That way you can replace it when the problem returns.
                  • Llama God
                    • Mar 2009
                    • 1353
                    That'd be a PCU then.
                      • 37491
                      Developer you can push as long as it is maintaining proper density and not starting to haze. I believe that on this machine you do one developer replacement and the next time you should replace the development unit.
