lanier ld425c
  • dgrow
    • Feb 2011
    • 26
    lanier ld425c
    This machine has gone black (LCD screen) and the printer lite is red as well as the alert light. I sent the print control board out to be examined by Hytec and it was returned with no problem found. Does anyone have any suggestions on what to do next? The hard drive was checked as well and showed no problem. Obviously I cannot even get into service mode because the screen won't light up. Please help!
  • JustManuals
    • Jan 2006
    • 9838
    Re: lanier ld425c
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • sandmanmac
      • 3981
      Re: lanier ld425c
      Does the machine go through the warm up cycle? Just with no display? Sending out the print controller was a big over-reaction.
      It's more likely just the Power inverter board.
      A bad Polygon motor can also cause a blank display, and would cause the printer light to be Red, because there would be an SC code being logged as well. You can check the code by logging into the WIM
        • 37532
        Re: lanier ld425c
        Did you try WIM to see if there was a SC?
        • dgrow
          • Feb 2011
          • 26
          Re: lanier ld425c
          Unfortunately I did not check the WIM. We took the machine out of the customer site and brought them a loaner thinking it would be best to work on it in our shop. The machine seems to start the warm up cycle and then stops and red alert light appears followed by the red light in the printer select button.
          • dgrow
            • Feb 2011
            • 26
            Re: lanier ld425c
            • sandmanmac
              • 3981
              Re: lanier ld425c
              So what's stopping you from checking it at your shop?
