Gestetner 1312 Sc Code 302
  • KHAN
    • Aug 2006
    • 261
    HI, friends i have gestetner 1312 , when i make one by one copy its ok ,but when making continuously, it shows SC 302 code.
    What i do? I change the ID sensor interval 1 min.
    But still the same result, Please need help ?
    THANKS.
  • joher
    • 43
    dear khan,,,,
    Only replaced the charge roller,,,,,,
    • rsyarcia
      Hair Straightener Tech
      • 711
      hi
      mr. khan before replacing the charge roller please check the drum if both sides of it has scratches or the metal already visible.In this case even you replace the CR the 302 will reappear.
      Nobody is perfect..
      • KHAN
        • Aug 2006
        • 261
        Gestetner 1312
        ok Thanks For Your Help I Will Check.
        Thanks.
