Ricoh Aficio 2045 misfeeding
  • tcypy1961
    • 773
    On this copier the paper is misfeeding and stopping as it goes into the switchback assembly and is kind of folding there. I pulled out the assembly and I believe the nylon rollers are giving me the problem. However, I wanted to ask and see if anyone else has had this problem and can confirm or deny that the rollers are indeed the source. Also the problem is worse when the copies are ran through 11x 8.5. Thank you for any help given.
  • Drummer
    • Feb 2013
    • 46
    Re: Ricoh Aficio 2045 misfeeding
    You want to make sure that the gates are not sticking in thier rest position. On these model machines the stops that the gates rest against have little pads to help keep things quiet when they open and close, those pads start to get gummy and cause the gates to stick, which in turn causes duplex jams.You can just remove them and it will work fine if that is the problem you are having.
    It is a very common problem on this series of machine.
    • sandmanmac
      • 3964
      Good call Drummer! The pads on the solenoids are exactly what's causing this. They sort of melt from the heat of the fuser I guess.
        • 36833
        They also deteriate from age and the crude in the air.
        • sandmanmac
          • 3964
          Just like me
          • JustManuals
            • Jan 2006
            • 9838
            tcopy - If you'd like a FREE copy of the parts and service manual, send me an email to paul@justmanuals.com and tell me who you are, and I'll send it along at no charge.
            Paul
            • tcypy1961
              • 773
              Yes, I can understand that problem if I was duplexing when the problem occurs but I'm just running the copies straight through, single side. So what else could be causing this problem?
              • rthonpm
                • Aug 2007
                • 2847
                More than likely it's those pads sticking. This used to drive us crazy when you'd get a call for duplex jams first thing in the morning and by the time you got there it was working fine since the gates had been in use enough to not stick. We used to call it 'morning sickness' back in Lanier days. Clean the exit junction gates for the inverter and remove the goop that's probably left of the foam and the adhesive for them and you'll be good to go.
                • Drummer
                  • Feb 2013
                  • 46
                  You dont necessarily have to be duplexing for these to cause an issue (especially if there is a 1 bin tray installed) ,although it is very apparent when duplexing. There is 2 sets of gates in that section that could be causing your issue.
                  After you've done a few it takes less than 10 minutes to remove them, If it doesent solve your issue, at least you have eliminated that as a possible problem.
                  Good luck
                  • Iowatech
                    Not a service manager
                    • 3930
                    You might check the gates that direct the paper either to the output tray or the duplex unit to make sure one of the fins isn't broken off, causing the paper to crash into the stub that remains (if that's the case, just file the corners off the stub and you'll be OK for the time for the time it takes to get a new gate to install).
                    Although, that should be easy to see because the lead edge of the jammed piece of paper will have a distinct dent where the broken fin is, so maybe not.
                    I guess there could be a burr on one of the gate's fins where the lead edge of the paper first contacts it, but that would also usually leave a dent in the lead edge of any paper jammed in that area.
                    If you have the scanner off the machine anyway, there's a three wire wiring harness that ends in a red male to male connector that you'll see. Make sure the wires aren't in contact with any rollers. If they are, it will intermittently short out 5V, causing all manner of stupid and wrong things to happen.
