SR5000 corner staple issues...
  • bollard
    • Nov 2012
    • 40
    [Misc] SR5000 corner staple issues...
    Hi all ref:
    SR5000 CORNER STAPLE ISSUES.
    Since stapler replacement unit staplers down the page ?
    If you push the hole unit back to the rear of the finisher you can get it just about right .
    Has anyone had issue with this at all I've cleaned and lubricated all working parts rail area white rollers etc.
    It appears that when the paper is jogged and dropped into the stapler,
    the paper is hitting the big side spring and folding the batch over before it fires.
    Ive read other threads but not shedding much light , also to add it works fine double staple with no issues.
