hi every 1 any one plz tell me how to install hard disk in Ricoh. also plz tell me thier is sapacail hard disk or any hard disk. how to parpare hard disk paration, file allacation systems fat or fat32 or ntfs pls tell me all
ricoh 1035 Hard Disk
theres no need to prepair the disk, format fat 32 and fit it in.sigpicWe can all Win, but at the end we all loose. Save the greyhound -
just plug same specs with the old hard disk... no hussle....fix the customer first then fix the machine... its simple and makes life more easy.Comment
ricoh 1035 hard disk
problem is still there
i format hard with fat32
but no responce
is there is some jumper satiing requiredComment
It needs to be at least 40GB and you dont have to do anything to it except make sure the jumper is set for single drive with no slave or master w/no slave.
The machine will partition and format it when installed.sigpic
A+; Network +; PDI+Comment
You don't have to do anything special to the HD UNLESS you are using a used HD out of another computer OR a later model Ricoh. All you need to do is make sure that the HD that you are going to install has at least 40GB of space. Just plug it into the controller unit and turn the machine on.
What problem are you having?
Is it throwing an SC8** code? Do you have duplexing capabilities? Is the Document server up?CompTia A+ Certified
CompTia Net+ Certified
CompTia Server+ Certified
CompTia Project+ Certified
OP Scanshare CertifiedComment
I use a 40 cause that what came in it. I keep in stock an 80 for the bigger machines a 40 for the mid volume and a 20g SATA for the 27sigpic
