MP201 scanner problem
  • buttalasso
    • Aug 2025
    Hi everybody,
    I have a strange problem with the scanner, you can see it in the attachment. I think it could be the lens unit, by I don't have another one to test it and it's the first time for me for this problem.
    Anyone had my actually problem?
    Thanks in advance
    20131028095207356.pdf
  • Polarbear
    • Feb 2012
    • 1070
    Re: MP201 scanner problem
    Looks to me like the ARDF is not sitting square on the copy glass. Are all the hinges ok, as the one on the left (that sits in a "pocket") can have the pocket crack and then the df sits skew on the copy glass.
    If the metal guide (that sits on the lower left of the df) does not fit into the slit glass guide, copies will skew, because they hit the slit glass guide.
    Also if the df does not sit square on the copy glass, light gets in and affects the copy.
    Press the GREEN button!!
    • mohan
      • Oct 2013
      • 86
      Originally posted by buttalasso
      Hi everybody,
      Thanks in advance
      [ATTACH]22644[/ATTACH]
      Looks like the scanner frame has bent. since there is no support on LHside of the scanner frame, anyone leaning on the frame (or sitting on it!) can cause the frame to bend, causing the mirrors to become out of parallel to each other, and cause apparent skewing of image. Brute force upwards at the left hand side of the scanner bed cures it. PS, on colour machines (C3000,4000 etc) it can also cause a blue cast on copy.
        • 37532
        Hi everybody,
        Thanks in advance
        Mohan's suggestion usually works for minor skewing in the optics. Always the first thing to try. Also check to see if the lamp is parallel to the mirrors. You might have to do a scanner alignment.
        • Blizzoo
          • Aug 2013
          • 608
          Seems like the MFC is new considering the total count on the tested document.
          I don't know this equipment but an opinion may help.
          I had a similar issue with an KM C350,in this case my problem was a plastic black pin,located below the scanner frame wich is designed help unit to slide easy (if I remember there are 4 of them,one on each side) and centering...that pin was missing and founded inside the scanner area due shipping on the "good roads" we have in our country
          • barratec
            • Jun 2008
            • 162
            Hi, i had the same kind of distorsion with a mp c2800. Mohan is right!
            Try to pull up strongly the left corner of the optics frame. I did it and the copy got quite perfect.
            • Sashko
              • Oct 2009
              • 110
              Another way - adjust the position of CCD unit, see attachement.
              • buttalasso
                Originally posted by Sashko
                Another way - adjust the position of CCD unit, see attachement.In my cases this solved a problem.[ATTACH=CONFIG]22657[/ATTACH]
                Sorry, I can't see the attachment.I changed the lens unit, but the problem is still the same.Can I imagine that it could be the BCU board?
                • kannuki2
                  • Feb 2012
                  • 398
                  I have had this problem on a MP2000 SPF. It may be different on this model but the problem is very exact. Double check the alignment of your B262 1700 Carriage: No.1 Unit in the scanner. Use output check on the scanner and see if the the scanner rail is moving freely. Good luck.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Originally posted by Polarbear
                    Looks to me like the ARDF is not sitting square on the copy glass. Are all the hinges ok, as the one on the left (that sits in a "pocket") can have the pocket crack and then the df sits skew on the copy glass.If the metal guide (that sits on the lower left of the df) does not fit into the slit glass guide, copies will skew, because they hit the slit glass guide.Also if the df does not sit square on the copy glass, light gets in and affects the copy.
                    I've had this on the MP201/301 and SP5200.Ricoh have this hinge holder as a retrofit part....phone them tell them that you need a hinge holder and they send it out for free.
                    • Sashko
                      • Oct 2009
                      • 110
                      See attachement
                      • buttalasso
                        Sorry for the late.Ricoh suggested to change the BICU, same result.I've checked the hinge, but I didn't see anything strange.See attached file.I'm working on it, I'm going to check the carriage
                        • buttalasso
                          Fixed!
                          First mirror out of position.
                          Thanks everybody
                          • SargeNZ
                            • May 2012
                            • 263
                            What fool at "Ricoh" told you to replace the BICU for what clearly is an optical issue?
                            • buttalasso
                              Not all the Ricoh technician have the same level of knowledge. The last collegue that answered me, told that was the first mirror, I explained the problem like past calls, he told me that he din't want to see the attachments, it was the mirror the problem. Fixed.
                              My problem is that I've never had a problem like this and so I've to ask to someone else.
