RICOH MP C3000/4500 faded print density deficient
  • tecnomarco
    • Jul 2011
    • 213
    Greetings to all, ricoh mp c3000/4500 prints density deficient, the test pattern is faded a polite ask your help on where I have to act to restore .... I also replaced the transfer roller and drum groups but the result is the same copies and prints that have faded and lacking density
  • Bantams
    • Jun 2012
    • 603
    Re: RICOH MP C3000/4500 faded print density deficient
    Try a forced toner supply in SP do each color then run the ACC in user tools if it goes faint again then replace all the devs and update the firmware.
      • 37446
      By drum groups, I am assuming that you mean the complete PCU and Development Unit. Since replacing the development units did not correct the problem, you could ave a problem with either a stuck laser optics shutter, dirty shield glasses, or a development or transfer bias problem.
      Use the cleaning tool found on the inside of the front door to clean the shield glasses. If the tool is missing, get one from another machine or buy a new one. Check the operation of the laser optics shutter. Some people will even remove the shutter. Check SP 3041-001. If it is set to 0, change it to 1. This puts bias voltage back to being controlled by the Process Control. Print a SMC non-default report. Anything that has to do with charge, development, or transfer bias that is not currently at default, return it to default.
      • turbojetboy
        • Aug 2009
        • 279
        I would remove the laser shutter first, if that doesnt fix it get back to us. FYI laser shutter is usualy identifiable by a simple test, open and shut he door and test cq after each time, does the cq change each time? The shutter moves back each time you open the door.
        • shenglang
          Hello everyone! ! My friend! Ricoh C3000 color copier results as shown, print effect is not a good question, is there such a failure this copier, optical also cleaned up, and fought copying prospective effect does not work! ! There are no friends friends to know that this is why, thank you!
          I will not send new stickers! ! Sorry! Thank you, my mail: shengxiaolang@126.com123457.jpg09822.jpg
          • m_donakov
            • 213
            I will not send new stickers! ! Sorry! Thank you, my mail: shengxiaolang@126.com[ATTACH=CONFIG]22717[/ATTACH][ATTACH=CONFIG]22718[/ATTACH]
            After several years i have same problem. I changed paper trasnsfer roller and nothing change. ONE THING VERY CONFUSE ME. I TRAY TO MAKE COPY WITHOUT TRANSFER ROLLER AND NO CODE COME UP.SO I STARTED TO THINK THAT ELECTRICITY IS PROBLEM. If anybody find solution please help
            Regards
            • Iowatech
              Not a service manager
              • 3930
              Regards
              For what it is worth, it probably would be more productive if you started a new thread rather than dug up these old fossils. You will get more techs looking at the issue that machine is pestering you with that way.
              If you can share pictures of the print defect that would help too. There are people from all over the world here that can help, we just can't see that machine or what it is doing.
              Sorry if this is a waste of time.
                • 37446
                Also most of us old farts who are most likely to know what you need to do will totally ignore anyone that reopens a 3 year old thread.
                • m_donakov
                  • 213
                  Ok i will start new thred. Thanks
                  • Iowatech
                    • 3930
                    Also, don't use the word "print" in the title of your new post, as that will automatically convert it to something we can't reply to.
                    Heh, that was mysterious to me when I first joined CTN too.
