Apparent MP C5000 Transfer Related C/Q Issue
  • Jeffjazzy
    • Aug 2011
    • 18
    Hello everyone. I have an MPC5000 that is leaving a lot of toner on 1 half of the Transfer roller resulting in background and streaks on half of the copy. I initially thought it was the ITB cleaning unit as when I first took it apart there was some paper stuck in the ITB cleaning unit and the mylar was bent out of shape. I cleaned it and still the same problem. I replaced it and still same issue. That black transfer roller on the duplex side is getting loaded up with toner messing up the C/Q. I ordered a new transfer roller but I am not to confident that will resolve the issue. Anyone seen this before and if so how were you able to resolve the problem? I'm enclosing a picture of the transfer roller. Interestingly it cleans the black toner off the ITB just fine. Copies look good on black. and although the picture seems to just highlight the yellow on the roller all the colors are actually accumulating on the transfer roller. Appreciate any help on this. Transfer Roller Issue.jpg
  • kannuki2
    • Feb 2012
    • 398
    Re: Apparent MP C5000 Transfer Related C/Q Issue
    You're having a drum issue due to dirty charge roller.
    • turbojetboy
      • Aug 2009
      • 279
      It's worn out PCU's - as simple as that.
      • shenglang
        Hello everyone! ! My friend! Ricoh C3000 color copier results as shown, print effect is not a good question, is there such a failure this copier, optical also cleaned up, and fought copying prospective effect does not work! ! There are no friends friends to know that this is why, thank you!
        I will not send new stickers! ! Sorry! Thank you, my mail: shengxiaolang@126.com123457.jpg09822.jpg
        • kannuki2
          • Feb 2012
          • 398
          Is that printed from the test pattern or you copy it on the glass?
          • sandmanmac
            • 3981
            Nevermind this idiot. He's hijacked a couple dozen threads today with the same issue.
            He should be booted to the curb!
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              I will not send new stickers! ! Sorry! Thank you, my mail: shengxiaolang@126.com[ATTACH=CONFIG]22715[/ATTACH][ATTACH=CONFIG]22716[/ATTACH]
              Time to kick the trash to the curb....................
              P.S. did aab1 move to southeast asia??????????????????
              Mystic Crystal Revelations
              • Tonerbomb
                • Feb 2005
                • 2589
                DONE !!!!!!!!!!!!
