Color counter
  • Faro
    • Sep 2012
    • 11
    Color counter
    Hello,
    I have a simple question. We work with some new Ricoh device and we activate the color lvl detection :
    - First time, my device work with the simple two counter : black and Color. I have 576 B/W and 1438 Color
    - I activate the color detection. I have new counter : BW : 576 (the same, ouf ) and Color total 1438 (the same, ouf again) aaannnddd 3 LVL counter : 1 : 140, 2 : 369, 3 : 302
    Soooo, my question :
    How work the color detection ?
    The total of 3 color counter is not egal to color total, it's normal ? I can change the % of color for LVL ?
    Thanks for your help and sorry for my bad english (I'm poor french technician)
    Faro
  • JustManuals
    • Jan 2006
    • 9838
    Re: Color counter
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
      • 37393
      Re: Color counter
      You need to be a bit more specific. What model Ricoh? Where did you "Activate Color Detection"? User tools or sp settings.
      Generally speaking, some models have setting where by them can display the amount of toner used. The numbers will have nothing to do with the total copies.
      • Faro
        • Sep 2012
        • 11
        Re: Color counter
        Device : MP C3503
        sp settings
        For be clear, before the technician modification :
        Page counter :
        Color Total : 1438
        B & W Total : 576
        (Some other number, Printer and Copier counter per example)
        After technician modification :
        B & W Total : 576
        Colour Total : 1438
        Color 1 : 140
        Color 2 : 369
        Color 3 : 302
        other counters disappeared
        I just like to have the calculation method for this
        Faro
          • 37393
          Re: Color counter
          The Color 1, 2, and 3 are color coverage counters. Level 1 is less than 5% total coverage. Level 2 is 5% or more but less than 20%. Level 3 is 20% or greater. I believe but am nor certain that the count is the number of originals and not copies. These counters are referred to as Accounting Counters. If the machine is on a service agreement where cost is based on usage, these numbers are used to compute monthly charge. If you still want to see counts broken down between between copy, print, and FAX, go to User Tools - System Settings - Administrator - Tools -Display/Print Counters.
