MP301 SC101
  • rrowens
    • Jan 2011
    • 17
    MP301 SC101
    In the service manual under SC101 it says defective darkness starting characteristic. Has any one heard of this. I cann't find any other reference to this that tells waht it is.
    • 37560
    Re: MP301 SC101
    SC 101 if I remember correctly has to do with scanning the white reference during power up. I usually see it when I forget and turn the MFP back on while I have the exposure glass removed.
    • Radman
      • Aug 2008
      • 24
      Re: MP301 SC101
      This is becoming a real problem on these machine and no where does Ricoh have a solution for this problem ........Has any one on here got a solution for this problem on the MP301.
      We have replaced the CTL BCU IPU SBU and no Joy. And yes we cleaned the white level plate.
      Currently I have 6 machines doing this at one of our major accounts.
      I will appreciate any information on this thanks
      • Polarbear
        • Feb 2012
        • 1070
        Re: MP301 SC101
        This is what the manual says:
        Symptom:
        Exposure Lamp Error
        The scanner has scanned the white
        plate, but cannot detect the certain white
        level.
        Cause:
        Press the GREEN button!!
        • Martie
          • Nov 2013
          • 11
          Re: MP301 SC101
          We have had the exact same problem with one of these machines and we replaced the scanner carriage unit assy (D1171651) which solved the problem. We did not replace anything else before the the carriage so the carriage was causing the problem with our machine.
          /M
          • Radman
            • Aug 2008
            • 24
            Re: MP301 SC101
            Thanks to all for your input. Well I have gone and spend some proper time on one of these machines and think I found the problem.
            I will try and upload a video later it seems that the some if the LED's on the scanner unit does not light up when checking the reference.
            Conclusion replace the scanner. Make sure you have stock of this item
            Thanks all
            • Polarbear
              • Feb 2012
              • 1070
              Can you not just get the CIS?
              Seems you can it just has an odd name:
              D1171651
              CARRIAGE:SCANN
              ER:ASS'Y
              • slot
                • Jul 2008
                • 341
                Re: MP301 SC101
                we have just had one do this this week ordered the scanner led unit and still got a problem we will try bicu as the harness are out of stock with ricoh
                will see how we get on
                • slot
                  • Jul 2008
                  • 341
                  Re: MP301 SC101
                  got one of the guys to fit a Bicu board which fixed the fault
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Re: MP301 SC101
                    We had one of these this week and it was caused by the LED array having some dead ones in the centre. Replaced the assembly and all was well.
                    I was surprised to discover that there is a CCD with SBU and mirrors as part of this assembly. This seems to be a combination of a LED array with CCD and not a CIS like we thought.
                    • aktasson
                      • Feb 2017
                      • 201
                      Re: MP301 SC101
                      I would like to give a comment about my field repair in this case. MP 301SPF SC142-00 and SC101-00 in SC History logged more times.
                      1. FW Update 2. Cleaning of fb glas, scanner mirror etc. and white line 3. White flatcable disconnected and plugged again to the sbu board.
                      All this has not helped!!!
                      After replacing Carriage:Scanner Ass'y D1171651 repair was successful.
