This one must be easy
MP 6500 Default PDF multipage
George Jetson
Hi Imind,
On a lot of the later ricohs you have to go into scan settings/file type and make and highlight multi page pdf. Then while this is your selection then press the program button then on the screen press program as defaults. This is a little different from the older models. Hope this helps. -
Hi Imind,
On a lot of the later ricohs you have to go into scan settings/file type and make and highlight multi page pdf. Then while this is your selection then press the program button then on the screen press program as defaults. This is a little different from the older models. Hope this helps.sigpicWe can all Win, but at the end we all loose. Save the greyhoundComment
Hi Imind,
