MPC3502
  • GeorgeBest
    • Jul 2009
    • 526
    MPC3502
    HI,
    Nice feature to put a logo on the home screen, but . .
    Can someone tell me how to put a logo into the this machine ?
    Did everything the manual said, put a logo in JPEG, max 45KB on an SD card.
    But when I load the picture from the operation panel in the mode "home adjustments"
    it cannot recognize from the SD card.
    Ther is not a special format for the SD card is there ?
    Can It be done throught WIM
    Thanks in advance
    George
  • Eric1968
    • 2458
    Re: MPC3502
    Use an SD-Card that is 1 GB or smaller.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Re: MPC3502
      Good point.
      For some reason, Ricoh is still in love with these tiny SD cards.
      If you don't have one, you may have to buy a few online, as you'll most likely never find one locally.
      • Eric1968
        • 2458
        Re: MPC3502
        I've tried it on an MP C3002 with a 4 GB stick and it didn't work. With the 1 GB stick I was able to load the picture.
        If you can't find a small stick, the SP5200S MFP comes with an SD-Card with only the language firmware on it. This is also a small card. After loading the language this card goes into the pocket for future use...
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Re: MPC3502
          Load it through the web page.
          Mystic Crystal Revelations
            • 37556
            Re: MPC3502
            Some model can use 2GB SD cards. To be on the safe side, I carry a couple of 512MB cards in my laptop case.
            Print from and scan to memory device also has size restrictions. Sales people don't always tell the customer.
            • Iowatech
              Not a service manager
              • 3930
              Re: MPC3502
              The SD card must be formatted with the utility from Panasonic, at least if you are using Windows. Windows default format doesn't work, apparently it formats a protected area on the SD card or something.
              • ruben
                The New Guy
                • Oct 2012
                • 1203
                Re: MPC3502
                That no longer applies, Windows built in format works fine; as long as you format to FAT or FAT32.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Re: MPC3502
                  On a similar note, we recently had a need to install an app on a few of the newer printers (not sure on the models right now) and even a 1 GB was too big; we had to use a 512 MB, which worked fine.
                  • Iowatech
                    • 3930
                    Re: MPC3502
                    Thanks for the update!
                    • Athlontini
                      • Jun 2012
                      • 269
                      Re: MPC3502
                      Has anybody tried partitioning a larger card to get a machine to recognize it? Seems like if you created a 1GB FAT32 partition from a 4GB card, the machine would see that partition and ignore the rest.
                      • Martie
                        • Nov 2013
                        • 11
                        Re: MPC3502
                        Yes, I have tried this and it works. I have used it on several models - old and new ones. But just in case I carry an extra 512 MB card to be safe.
