Ricoh aficio mp c400sr sc672
  • salvador zambrano
    • Nov 2011
    • 25
    HI, I am working on a ricoh aficio MP C400SR and I keep getting a sc672 code every morning. Any ideas or what this code means? Thanks
  • Bantams
    • Jun 2012
    • 603
    Re: Ricoh aficio mp c400sr sc672
    Controller-to-operation panel communication error at startup
    After powering on the machine, the communication circuit between the
    controller and the operation panel is not opened, or communication with
    controller is interrupted after a normal startup.
    Controller stall
    Controller board installed incorrectly
    Controller board defective
    Operation panel connector loose or defective
    672 CTL
    D
    1. Check the harness connection.
    2. Replace the controller board.
    • salvador zambrano
      • Nov 2011
      • 25
      THANKS!!!! FOR THE HELP!
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
        http://www.justmanuals.com
        paul@justmanuals.com
        • Moza
          • 232
          Had SC 672 from memory dimms but on different models to this, I would start there
          Maybe controller or BICU after that
          • Polarbear
            • Feb 2012
            • 1070
            On these modern controllers memory, hdd or even NVRAM can cause this.
            Before I replace a controller, I first disconnect the HDD, then restart the machine, then do the same with different RAM, and only then if the code persists do I replace a controller, as these are very pricey the side of the world.
            Press the GREEN button!!
