Memory Full MPc305spf
  • MitchD
    • Oct 2012
    • 164
    Hello, I have a brand new MPc305spf that when the customer runs more that 3 full color originals to make just 1 set of copies they get a memory full message. Printing and scanning are both just fine.I have read the service manual and operators manual front and back and cannot find anything to correct this issue. I did find a setting in input/output to continue to print after memory full, but that didn't solve my issue.
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
  • SargeNZ
    • May 2012
    • 263
    Re: Memory Full MPc305spf
    I would pull and reseat the RAM cards, and update the firmware first up.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Definitely sounds like a RAM issue. Re seat it and update the firmware, if updates are available, as suggested.
      After that, replace the RAM.
      • MitchD
        • Oct 2012
        • 164
        Sounds good. I will try that and let you know. Thanks for the responses
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          What is the ready memory usage percentage? Have you installed the HDD option? This model has 1GB of RAM, this is shared between copier, printer and fax, so make sure you clear any stored fax jobs.
          • nmfaxman
            • 1702
            Ran into this on a MPC3501.Check status of HDD from Control panel.Mine had 0% available.Reformatted and all was well.
            • MitchD
              • Oct 2012
              • 164
              No HDD installed, they are only using it to copy/print/scan and there were no print or scan jobs in memory.Im going out today and trying to re seat the memory and update firmware just in case
