ricoh 1035
  • red flower
    • 28
    ricoh 1035
    when i power on the machine it stop on please wait screen but when i disconnect its harddisk it works normally i want to know if this problem can solve with download firmware and which one (fcu-mcu-mfp-bicu'bcu)
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    Sounds like you need to replace the HDD.Dont know if flashing will help but it is the cheaper route to go.
    • Kopyrtek
      Copier Psychologist
      • Jan 2007
      • 407
      If you flash the copier you might as well do them all.
      • copygirl
        • 75
        You can try to reformat the HDD. Don't know if firmware will help. Have had several HDD's that we've had to replace. I would do format it first. Good Luck.
        Ginger
        • Jomama46
          • 2900
          Here's my two cents. Replace the HD.
          sigpic
          A+; Network +; PDI+
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            • Jomama46
              • 2900
              "Vacuum Senior Tech A+" What the hell is that? LOL
              sigpic
              A+; Network +; PDI+
              • iMind
                • Mar 2008
                • 1116
                • Jomama46
                  • 2900
                  I hear ya, Dude!
                  sigpic
                  A+; Network +; PDI+
                  • red flower
                    • 28
                    Thank you for help
                    • ZeusGT
                      • 271
                      HDD!
                      CompTia A+ Certified
                      CompTia Net+ Certified
                      CompTia Server+ Certified
                      CompTia Project+ Certified
                      OP Scanshare Certified
