Ricoh aficio mp-2510 change language
  • Philip64
    • Mar 2013
    • 3
    Hi there, i have an aficio mp-2510 but the display language is in nederlands and french. so its hard to understand. can anybody send me the english language file to my e-mail.
    So may copy the file into the ic memory card and then in the copier?
    • 37490
    Re: Ricoh aficio mp-2510 change language
    There is no separate English file. All installed languages are contained in the Language Update. When you install the update, you can then select the two languages to have on the machine. I would recommend updating all the machine firmware first as sometimes the Language Update requires the machine firmware be at a specific level or later.
    • Philip64
      • Mar 2013
      • 3
      Can you send me the language update and all the machine firmware to my email account.
      Thank you
        • 37490
        Thank you
        If you are a Ricoh tech, you should be able to obtain those directly from Ricoh's service and support sites. Otherwise, contact a Ricoh service center and have them come out and update your machine. Also, check with JustManuals. Paul sometimes has firmware available for purchase.
        • JustManuals
          • Jan 2006
          • 9838
          With 3 posts it's highly unlikely.
