MP2000/MP4500 : Number Ring Tones
  • AleLeader
    • Oct 2012
    • 29
    I have MP2000 & MP4500 but i can not found where change NUMBER RING after FAX RESPOND when setting Automatic Mode!!!!?!!!!
    • 37628
    Re: MP2000/MP4500 : Number Ring Tones
    On most Ricohs rings are set using the FAX SP parameters. On most machines line 1 is set using SP 2-103-007 (G3 NCU parameter 06) in FAX SP mode. SP 2-104-007 and SP 2-105-007 are for lines 2 and 3. Actual SP numbers for your machines might be different but the discription should be the same. Check the FAX SP sectuion of your Service Manual.
