Ricoh Aficio 3260c light black copies / prints
  • mkelly1967
    • Dec 2012
    • 25
    Hello everyone,
    I have a Ricoh 3260c that had a bad black toner pump and was adding too much toner causing spots on the paper and getting on the transfer belt. I replaced the pump and that issue was fixed. Now it is printing too light. If I try to calibrate the copier it cycles and does not print a calibration page. After I noticed that it was taking too long calibrating I cycled the power. It was then over-toned. I cleaned the music sensors first which were dirty. That did not help. I had a transfer unit from a machine in the shop that was working fine and threw it in the copier. Still same issue.
    I know it is something simple that I am not seeing. Please help!!!
    Thanks in advance for all your professional advice!!!
    Mike
  • Gift
    • Mar 2011
    • 2459
    Re: Ricoh Aficio 3260c light black copies / prints
    Perhaps the developer, dv unit or drum is faulty. I can also imagine that the process controll/td values might gotten off limits due to the problems. Dunno if somebody tried to toner up the machine manually (up to a level where black looks ok but not over the top) and then perform a TD sensor initialisation. Works for me in some cases - I recall having some issues with these machines getting lighter in low volume enviroment - but all in all far better than the newer models MPC6000 onwards^^
    Albuquerque - sweet, perhaps some blue meth got into the dev unit
      • 37489
      By transfer unit do you mean the paper transfer unit or the ITB? If it was not the ITB, check that the black transfer roller.
      • JustManuals
        • Jan 2006
        • 9838
        paul@justmanuals.com
        • Counsel
          • Aug 2011
          • 529
          After fixing the toner issue did you go into sp mode and do a manual toner add, then run Process control Density and normal and check result it may just need to calibrate process control.
          • Ramón
            • Mar 2011
            • 26
            I think you can also think that the pump has too much air inside and not suck either toner. You can try to manually fill toner reaches the tube using a syringe pump to the vacuum to the pump and try to make a toner refill the SP 2251-001.
