Ricoh 1075 gives open door all the time ?!
  • copy.eva
    • Jun 2012
    • 33
    I was changing the toner bottle motor, and then the machine started showing open door, ive put back the old motor but still the same. Any help would be appreciated
  • mohan
    • Oct 2013
    • 86
    Re: Ricoh 1075 gives open door all the time ?!
    Assuming you have checked the door switches (one top left, other bottom right), check that you haven't inadvertently disconnected the drum unit and/or the dev/toner connectors.
    • Polarbear
      • Feb 2012
      • 1070
      Have you maybe blown a fuse on the power supply? I know some blown fuse conditions result in false door open errors.
      Press the GREEN button!!
      • mikadonovan
        • May 2008
        • 2931
        Check FU109 on the PS.
        NEVER ASSUME ANYTHING
