Ricoh 2020D Waste Toner Disposal
  • sparky030405
    • Sep 2013
    • 6
    Hi
    Does anyone know how to locate and remove the waste toner on a Ricoh2020D?
    Printer has started to print faintly. Have replaced toner cartage but still persists.
    Any tips for self maintenance, servicing of the unit? I am located in country area, not services by Ricoh.
    • 37489
    Re: Ricoh 2020D Waste Toner Disposal
    I believe the 2020D does not have a waste toner container. Excess toner on the drum is cycled back into the developer.
    Two things to check:
    1. You may have dust build up on the shield glass. Most of these entry level models have the shield glass located under a small pull out cover below the toner bottle tray. You may have to lift the toner handle to see it. Slide the glass out, it usually has a strip of plastic film to pull it with. Clean it with a clean dust cloth and reinstall it.
    2. If you have over 60K since the last time the PCU was rebuilt, you will need a PMB12160K PM kit, B0399510 OPC Drum, and B1219640 Developer Type 28.
    • JustManuals
      • Jan 2006
      • 9838
      paul@justmanuals.com
      • mikadonovan
        • May 2008
        • 2931
        Like
        NEVER ASSUME ANYTHING
        • Llama God
          • Mar 2009
          • 1353
          Whatever happened to the "Like" button? I like this, it's good
            • 37489
            Aneurysm has his hands full trying to correct every that has gone wrong since the hack. I kind of think that there might still be some hacker coming in and doing small changes every couple of days.
            • rthonpm
              • Aug 2007
              • 2854
              vBulletin has been the target of quite a few hacks and vulnerabilities of late. Poor Aneurysm is probably on the verge of one right now with all the hassles he's had.
