Part Number needed
  • skynetto
    • Sep 2012
    • 257
    [Misc] Part Number needed
    Can someone please confirm thet D377 0581 is the right part number for Printer/Scanner card on a MPC2800?
    Have a machine without it and I'm not enable to find it in parts catalog.
    Thanks in advance
  • Jomama46
    • 2900
    Re: Part Number needed
    D377 is the code for the C300 controller but I think the C2800 comes standard with the print scan and doesnt need a sd card or anything else as it is all in the controller board.
    sigpic
    A+; Network +; PDI+
    • skynetto
      • Sep 2012
      • 257
      Well that's strange because I have two controllers and none of them is showing the scanner option and the printer is only on USB. I've enabled ethernet card but cannot configure it thru WIM because I don't see it in the sytem settings (there's no lan interface in settings).
      Two of them broken?
      BTW when will the Like button come back?
        • 37533
        Try checking the Product Support Guide.
        • Jomama46
          • 2900
          Two of them broken?
          I dont know what to tell you except make sure it is a d023
          sigpic
          A+; Network +; PDI+
          • hosennet
            • Mar 2007
            • 145
            Controller Option
            D377-0581 SD-Card - Service
            • skynetto
              • Sep 2012
              • 257
              Problem solved. NVRAM was damaged. Changed with a new one and now it working fine.
              Thanks.
