Ricoh Aficio MP C4500 Z-Fold jamming at registration
  • mkelly1967
    • Dec 2012
    • 25
    Hi,
    I have a Ricoh Aficio MP C4500 that jams every 10 pages or so at the registration roller. I noticed that the roller does not have a clutch on it. Could it be the one way bearing or the drive motor for the roller?
    Any help is much appreciated!!
    Thanks!!
    Mike
  • turbojetboy
    • Aug 2009
    • 279
    Re: Ricoh Aficio MP C4500 Z-Fold jamming at registration
    2 possibilitys I know of. Remove reg guide and inspect the mylar behind it for cuts and wear. Replace the PTR (b2236264 from memory) as I have seen these cause z fold for no obvious reason.
    • collme
      Ricoh tech
      • 221
      seen them reg guides slightly bent giving intermittent z folds as well.
      • JustManuals
        • Jan 2006
        • 9838
        http://www.justmanuals.com
        paul@justmanuals.com
          • 37533
          Originally posted by mkelly1967
          Hi,
          Thanks!!
          Mike
          Some machines do not use a registration clutch. They use a motor that drives only the registration roller. If 0 he motor has a dead spot, you will get intermittent jams. Another problem could be the relay clutch sticking. Relay roller dooes not stop soon enough and you get a z-fold jam.
          One more thing, did you check the paper in the tray. I had a call one time for jamming. Every tenth sheet of paper had about a one inch z-fold. Apparantly had come from the paper mill that way. Folded before being cut to final size.
