LD425C double feed in bypass
  • bdlanier
    • May 2025
    [Misc] LD425C double feed in bypass
    I have replaced sep assembly and tension spring, during sep assembly replacement all areas of bypass unit looked proper. the bypass will pull five sheets or more at a time consistently, any suggestions would be apriciated.
  • qbert69
    • Mar 2013
    • 1152
    Re: LD425C double feed in bypass
    ....try a different ream of paper???....change paper orientation...lengthwise vs crosswise???
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • bdlanier
      thanks for the suggestion, i have tried different orientation and paper with no improvement.
      • Iowatech
        Not a service manager
        • 3930
        Sounds like the separation roller torque limiter might have failed or might not be installed correctly.
        I guess something that prevents the proper pressure between the feed and sep rollers could cause that, too. As it sounds like you had that part of the machine disassembled you should probably check this first before you replace any parts.
        • JustManuals
          • Jan 2006
          • 9838
          http://www.justmanuals.com
          Paul@justmanuals.com
