MPC 4502 jamming under the fusing unit!
  • fritzyas
    • Jul 2011
    • 73
    We have a problem with a MP C4502 machine, when copying/prntng the paper will stop under the fusing unit. Changed already the exit/entrance sensors. Fusing/exit motor is working. Thanks for your help.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC 4502 jamming under the fusing unit!
    What do the INPUT checks say?
    • fritzyas
      • Jul 2011
      • 73
      the input check on senors are normal, and also replaced some just to isolate if defective.
      • Gamut
        • Jul 2008
        • 216
        jam code?
        is it all trays?
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Start from the basics; check that the tray orientations are set to auto or manually to the correct value.
            • Counsel
              • Aug 2011
              • 530
              Do you hear any noise when it runs, The PTR discharge fins have been known to get bent and catch paper or make a paper shredding sound. Look at the PTR and see if any of the little metal fins are bent outwards if they are I usually just clip off the few that get bent.
              • Debs1964
                • Oct 2010
                • 1690
                If it's jamming just before the fuser, this is what I'd be looking at too
                There are 10 types of people in this world, those who understand binary maths and those who don't
                • rsyarcia
                  Hair Straightener Tech
                  • 711
                  this is the same problem that we have and it was the fusing sleeve that is causing the problem.
                  Nobody is perfect..
                  • kannuki2
                    • Feb 2012
                    • 398
                    Agree with counsel. It's the paper transfer roller bias plate.
                    • muthuk7
                      • Aug 2010
                      • 57
                      fusing sleev might be an issue
                      we had it the same
                      • sg01
                        • 16
                        Check the fusing sleeve and replace if necessary
                        also check the Bias Plate (the one with many metal teeths) located on the PTR.
