MPC 6501
  • Roger67
    • Nov 2013
    • 84
    [Error Code] MPC 6501
    Hello Folks,
    i have a MPC6501. Who makes First a. SC 550 and later a SC 542 ( 542 its not in the Service Manual ).
    I changed the complet Fusing Unit and i have the Same Problem.
    Does any One has any Ideas ?
    thanks for Infos
    greetings
    roger
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: MPC 6501
    power supply but id check that there's no paper or tiny scrap of paper behind the fuser connector before ordering any boards.
    Incontinentia Buttocks
    • Roger67
      • Nov 2013
      • 84
      Re: MPC 6501
      Hello,
      the Connectors are clean.
      The 4 Heating Lamps are o.k. But i have Not enough Heat.
      i think the Problems comes from any Board.
      roger
        • 37375
        Re: MPC 6501
        SC 542 is a thermistor error. Did you reset the the fusing unit code with SP5810? Just replacing a defective fusing unit part will not clear the code unless you reset it.
        • Roger67
          • Nov 2013
          • 84
          Re: MPC 6501
          Hello,
          Yes i have reset it a couple of times with 5810 and 7807.........
            • 37375
            Re: MPC 6501
            Originally posted by Roger67
            Hello,
            Thank you for the reply.
            • Roger67
              • Nov 2013
              • 84
              Re: MPC 6501
              Dear all :
              The reasen for my SC542 was simple the fact that i instslled a Fusing
              Unit which i had in my Car for a couple of days during cold weather conditions while
              the car is standing outside.
              So the fuser was very cold when i installed it.
              One of the Thermistors shut of because of the temperatur
              difference.
              I only had to push ut back in normal Position.
              Anyway.thanks for your tips.
              Cheers
              Roger
