Sensor Location
  • kyvahe
    Sensor Location
    Can someone point out the location of the ID Sensor for me please? I've read it is behind one of the drums (the drum?), but I'm not sure what it looks like so I can clean it.
    I am getting error SC385. TIA.
    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
  • joshuadenmark
    Re: Sensor Location
    Take a look behind the fusing unit
    • Bantams
      • Jun 2012
      • 603
      Re: Sensor Location
      TOP left behind the silver shutter cover with the black tab on the end that moves the shutter when the pcu cover is closed
      • JustManuals
        • Jan 2006
        • 9838
        Re: Sensor Location
        Paul@justmanuals.com
        • KapeKopyTek
          • Nov 2013
          • 284
          Re: Sensor Location
          You'll have to push the shutter in, this will expose the sensor(s). Use a vac to clean out the opening(s). Or, you can remove the fuser, and remove the entire sensor assy and clean it that way, reseats the connector in the process.....
          • Eric1968
            • 2458
            Re: Sensor Location
            http://imgur.com/4iX1mf9
            I've got just one comment on this :
            Call a tech!!
            • Llama God
              • Mar 2009
              • 1353
              Re: Sensor Location
              So many numpties with a screwdriver...
                • 37560
                Re: Sensor Location
                Fuser unit has to be taken out in order to replace the ID sensor board. Repeated SC 385 usually indicates that the ITB cleaning unit needs to be replaced. If you had a service manual you would have known both of these facts.
