I have aficio 1015 with ghost imaging. I replaced the heat roller, heater lamp thermistor and pressure roller but the problem wont go. Its affecting the top side and the bottom side. What is the solution.
Ghost image
Re: Ghost image
What's the density of toner in prints,can u feel it under your fingers,check if toner type is "for use",did you replaced hot roller with "for use" one?
Try enabling Fusing idling on SP mode,inspect thermistors and bearings,I change those on every hot roller change...with fingers ofc.
If you tryed another PCU in that machine it doesn't mean it will form better image,machine engine may still add more toner no matter what PCU is inside,because it remembers the settings for previous PCU.
Ensure that all assembly's are working proper before the one causing problemsGears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?Comment
