MP2852 hangs after copying 1 page.
  • fritzyas
    • Jul 2011
    • 73
    This machine has no problem when printing but when copying it will hang after a copy. doesn't show any sc codes on the SP Logs. any idea about this problem.thanks in advance.
  • JustManuals
    • Jan 2006
    • 9838
    Re: MP2852 hangs after copying 1 page.
    Paul@justmanuals.com
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      What about copies? Firmware up to date? a particular file?
      Incontinentia Buttocks
      • Iowatech
        Not a service manager
        • 3930
        If that happens when you place the original document on the platen glass, either turn off sorting/duplexing on the touchscreen before making copies, or press the "#" key after the first copy comes out.
        • fritzyas
          • Jul 2011
          • 73
          the firmwares were up to date. copying through the ardf and platen is the same it will just hang after a copy then shows processing but no reaction from the machine. we replaced the bicu but still no improvements.tnx for the replies.
          • Helios
            Where is it scanning to? FTP? SMB?
            • fritzyas
              • Jul 2011
              • 73
              scanning not utilized with the machine. they are using it mostly for copying.
                • 36812
                ince it affects copying and not printing, I would look to those items having to do with copying. The IPC PCB and the lens unit assembly and SIO PCB in the scanner area.
                • lky1978
                  • Mar 2009
                  • 475
                  Check optical area, clean the mirror if necessary.
                  • johnyb
                    • Feb 2011
                    • 167
                    Hi I have had this issue, and believe it or not....Got Ricoh out and, t was a corrupted NVRAM causing the issue...NVRAM cleared then set up, not heard anything since that was about 8 months ago!
                    The controller, HDD, IPU, Memory had all been replaced, beforehand.....
