Priport Gestetner5700+
  • cliffhangers
    • Feb 2010
    • 243
    Am haven problem with PriportGestetner5700+ it's printing well when i scan master from other priport and Rab it on the drum it print with no problem,the problem is it can not cut master because the drum done open or turn to receive master when it is coming it then displayed master jam.i try the master unit and drum on other priport it works well.i need help on this,THANKS IN ADVANCE.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Priport Gestetner5700+
    if the machine is workin using other drum then you have to compare the defective drum to the working one.
    Nobody is perfect..
      • 37652
      I would check the drive mechanism for opening the master clamp on the drum or the drive timing for the drum.
