MPC 2550 Always add toner
  • Frank12
    • Nov 2008
    • 77
    Hi all,
    MPC 2550 always add toner black even do i change a new toner.
    Thank you
  • JustManuals
    • Jan 2006
    • 9838
    Re: MPC 2550 Always add toner
    Paul@justmanuals.com
    • sandmanmac
      • 3983
      Originally posted by Frank12
      Hi all,
      Thank you
      Check the lower right cover is closed properly.
      It happens routinely. It sometimes happens when the new toner is loaded, but doesn't show, and toner will not be loaded. Otherwise check, clean, and/or replace toner hopper
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Do not completely clean the inside of the toner hopper, there needs to be some toner present for the sensor to detect. Also, check that the plate above the hopper hole moves freely and then check to see if the paper tags on the new toners have been removed.
        If it is only happening with one toner, it could be a fault hopper. They come as individual units; really easy to replace.
        • Mad_Coachman
          • 99
          Hi all,
          Thank you
          Faulty toner cartridge. I have seen this twice with Toshiba toner so try another cartridge.
          • Mad_Coachman
            • 99
            Sorry...wrong brand
            • Aneesh
              Try to replace hopper unit, there is a small bottle of toner comes along with the new hopper unit. also check the SP mode setting for toner empty dictation
              • ashley
                • Jun 2014
                • 1
                I have the problem first I changed the toner thinking it was faulty then dev change but call came back after week.Im going down the hopper route.
