Ricoh Aficio 3035
  • Subtrax1
    [Misc] Ricoh Aficio 3035
    I work for a charity and we have just been donated a Ricoh Aficio 3035. I am trying to set this up on our network but there does not seem any network settings. There is a lan card installed and the lan lights up when you turn the machine on, but then the lights go off after a few seconds. I have logged in using admin username and it says I am logged in but cannot find network settings anywhere. can anyone help?
    Thanks.
  • sandmanmac
    • 3964
    Re: Ricoh Aficio 3035
    The network port is standard, however the accessories to enable printing/scanning aren't.
    A couple of questions:
    - Does it have "printer and scanner" buttons below the 'copy' button?
    - The network settings (If installed) would be under 'User tools' / 'system settings'/ 'Interface settings'/etc.
    - There is a small narrow metal cover with 1 screw above the network port on the machine. There are 3 SD card slots underneath it. The top one (C1) should have a printer/scanner card installed. (there is also a memory dimm required to be installed on the controller board, but this is a good start)
    - If you don't have any/all of the above, you don't have printing / scanning capability. If you do, it may need to be enabled in service mode
    • Subtrax1
      Thanks for getting back to me so quickly. These are the only ports It has installed. The machine has 2 buttons: Copy and Scan. Would it be possible to purchase the print kit for this? Is it worth it?
      Thanks.
      • TonerMunkeh
        Professional Moron
        • 3865
        This is what you'd need.
        Is it worth it to you? Bear in mind these things are filthy buggers too. They take a fair bit of looking after, regular vac outs etc. On-time replacement of certain PM parts and OEM toner are a must. Maintain it well and it'll run happier.
        Hit it.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • kannuki2
            • Feb 2012
            • 398
            Yes, contact one of our Ricoh offices for a quote on price. I think this machine is still worth for a print kit.
            • Herostrat
              • Oct 2012
              • 220
              Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
