printer, scanner and fax..
  • msmy
    • May 2010
    • 123
    Hi,
    I have MPC4500 which is dont appear the printer, scanner and fax option in the service mode.
    Could anyone please help me how to solved this problem (enable of these three functions).
    thank you.
    • 37532
    Re: printer, scanner and fax..
    If you have the buttons on the operation panel, then the SD card is either missing, defective or not fully inserted. The other posibility is a defective controller board or ram.
    • sandmanmac
      • 3981
      All good points.
      Wouldn't you think that the poster could at least have provided some of the information that he has checked or tried other than pressing the 'user tools' button.
      My guess: no printer/scanner/fax installed
        • 37532
        Originally posted by sandmanmac
        All good points.
        I think it might be an end user. I don't think I would have a tech who does not know the difference between "User Tools" and service mode. I forgot to comment on that on my first post.
        • sandmanmac
          • 3981
          I would tend to agree with you, except his lengthy post history includes Ricoh, and many different manufacturers, which is what's so bothersome.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            I think the gene pool of the consortium is being diluted.............
            Mystic Crystal Revelations
            • msmy
              • May 2010
              • 123
              Thank you very much guys for your good support.
              • Llama God
                • Mar 2009
                • 1353
                Wow. Still, I'll have a stab at fault-finding.
                Does it have fax "line" and "tel" connectors on it?
                Does it have a print/scan SD card in it?
                Does it have print, scan and fax buttons on the ops panel?
                Does it have a fax board inside the controller in the back of the machine?
                Have you enabled the network card?
                The simple answer to this wholly vague question is that there isn't a simple answer. If you can provide some information then it'll be an awful lot easier to help. On the other hand, if you simply can't be arsed then it's pretty much game over. As things stand, your question can be summarised as follows:
                "This no work. Why?"
                • Llama God
                  • Mar 2009
                  • 1353
                  And from this, having thought about it for literally 10 seconds, I can deduce that either you're an end user or a very poor technician. No offence.
