MPC-305 spf : no print/copy at energy-save-mode
  • Zeldaman
    • Mar 2011
    • 946
  • Zeldaman
    • Mar 2011
    • 946
    Re: MPC-305 spf : no print/copy at energy-save-mode
    Hi there!
    1. feedback: 24 hours gone since changing the sp-mode, no call until now.
    Greetings...
    • Llama God
      • Mar 2009
      • 1353
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      I'm liking this, partly because you posted your findings but mostly because you say "Greetings" after each post. It's brightened up an otherwise dull evening.
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        1 week is over, and no call. It seems that the problem is solved.
        Greetings...
        • TonerMunkeh
          Professional Moron
          • 3865
          SC code description, in fantastic English:
          5191
          [Mode Set]
          Shifts to the power save mode or not.
          001 Power Str Set *CTL
          [0 or 1 / 1 / 1/step]
          0: OFF, 1: ON
          Beats the section called "Tonner Suppry" in the Metis manual though. I wonder if they were taking the piss on the translation.
          Hit it.
          • Zeldaman
            • Mar 2011
            • 946
            Hi there!
            The gag is that in my manual is no descreption of this code!
            Greetings. ..
            • djremixer
              • Feb 2014
              • 18
              hello
              I have the same problem
              machine 1 year old
              no intervention needed
              until now that machine doesn't wake up anymore
              sometimes it does
              SP5191 allready adjusted
              new power supply unit and new ACVB board (or something like that)
              ordered now new ctl and new bicu
              @ zeldaman: did you replaced the CTL?
              • Zeldaman
                • Mar 2011
                • 946
                • djremixer
                  • Feb 2014
                  • 18
                  they were update last week.....
                  but how can something starts itself than?
                  some machine start getting this and some others don't
                  same firmware and nothing was changed (no technical intervention)
                  you should think if it was the firmware they should have that problem from the beginning and all machines would be affected with that firmware
                  but i will check this tomorrow
                  • Besserwisser
                    • 25
                    Hi
                    Anything new about this problem ? I have 4 machines that suddenly dies...have tried new firmware and the secret SP 5191...
                    • djremixer
                      • Feb 2014
                      • 18
                      no solution yet
                      • Zeldaman
                        • Mar 2011
                        • 946
                        Hi there!
                        Had 2 ones with defective controller-boards, both only 2 month old!!! Change the board & never heard again of them since 6 months.
                        Greetings...
