mpc305spf
  • jtd55
    • Dec 2013
    • 30
    [Misc] mpc305spf
    Hi guys/girls
    Im a new member but been working in trade for 20 odd years mostly ricoh
    I installed this above machine in Aug this year been out to it for various problems
    ADF wont Feed, Paper jamming and finally pink line on edge off copies which i
    had to change the magenta PCDU ( Only 330 print colour max) they run an Aficio 1515
    for years no probs but wanted to update to a colour A4 machine am i right in thinking that the latest
    kit coming out of Ricoh is crap these machines just look so fragile. !!!
  • Eric1968
    • 2459
    Re: mpc305spf
    Ricoh uses more plastic parts in their new machines to reduce the weight. I haven't had serious problems with them. Maybe you just had bad luck with this one.
    • Zeldaman
      • Mar 2011
      • 946
      • joshuadenmark
        Re: mpc305spf
        Not to mention defect tonerhopper...
        • didspip
          • Sep 2008
          • 11
          Re: mpc305spf
          Hi guys,
          I have an MPC305SPF that is intermittently asking for yellow toner even though it is over half full.
          There is also excess yellow toner inside the machine.
          You mention defective toner hoppers and toner boards, is this a common fault? If so what is the fix please?
          • ruben
            The New Guy
            • Oct 2012
            • 1204
            Re: mpc305spf
            Originally posted by didspip
            Hi guys,
            Faulty yellow hopper, faulty cyan hopper, faulty yellow drum, faulty high voltage board behind hoppers, faulty laser registrations, etc. Do not buy any more of these machines, you will lose money.
            • Polo-022
              • Sep 2007
              • 481
              Re: mpc305spf
              Check for a broken toner dispensing auger, or maybe poor toner cartridge contacts...( it is not so bad to build some more experience with this rat trap!! It has everything you can see worn,bent,broken,faulty,burned....)
              • Gift
                • Mar 2011
                • 2439
                Re: mpc305spf
                Unfortunately most latest engines seem to appear pretty "cheap production" like - not much fun working with the stuff anymore. But if your honest it's not just a Ricoh phenomenon since most brands try cutting costs and prices.
