MPC 2500
  • staffie man
    • Aug 2011
    • 59
    [Electrical] MPC 2500
    Hi all.
    Just wondered if anyone has any ideas on this fault, I got a call to a customer with error code sc547 and discovered fuse 101 on psu(8 amp-250v) was blown,customer said they thought power cable was faulty and replaced it with another printers cable, I replaced it with the correct cable & replaced the fuse (5 amp-250v it was all i had at the time) & 10 days later got a call back with sc 547 blown fuse again I then fitted the correct rated fuse, customer has m/c plugged into a power surge socket & claims no other m/c is affected ,thanks in advance & merry christmas to all.
    • 37556
    Re: MPC 2500
    SC547 is a zero cross error. Could be a defective PSU.
    • collme
      Ricoh tech
      • 221
      Re: MPC 2500
      Had this on a MPC3300 this week although mine blew straight away and was caused by the pressure arm spring coming loose and shorting the lamps. I realise your fault can't be the same as it does run for a while before blowing the fuse, but the fuser could be good place to look at to start with.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Re: MPC 2500
        HAve you actually measured the power at the outlet to see if it is correct?????
        Mystic Crystal Revelations
        • staffie man
          • Aug 2011
          • 59
          Re: MPC 2500
          Thanks for the replies, the m/c has been in situ for three years with no problems & has a surge adapter fitted, the fuser unit was replaced at the same time as the 5 amp fuse was fitted, I have fitted the correct fuse & am waiting to see if this blows too but the m/c is in a school so wont know till after the holidays, thanks again.
          • SOHAIL
            • Feb 2019
            • 2
            Re: MPC 2500
            Hi guys
            SC 547 error . I checked all fuses are ok
            Copier was working ok i replaced only paper lift up motor when i installed the power supply i got this error any one can guide me
            Please
            • Masterchief
              • Apr 2011
              • 280
              Re: MPC 2500
              Have you ensured the cables are all reconnected properly
              Maybe you have placed the fuser cable in the wrong place
              sigpic
              • SOHAIL
                • Feb 2019
                • 2
                Re: MPC 2500
                Thank you very much i solved the trouble .
                Yes you guys were wright the problem were from Fuse.
                coz without removing i checked and found ok but when i remove from slot and checked then i found it was blown up
                replaced it . Thanks
                  Re: MPC 2500
                  Originally posted by SOHAIL
                  Hi guys
                  Please
                  wow talk about kicking a dead horse ...
                  as a newbie .. may I suggest starting you OWN NEW thread and list like the OP on this thread..
                  Page Counts Machine/Supplies
                  work done on machine
                  (in your case) measure wall voltage.. any surges etc
                  New/Old Wiring
                  things that might help us more
                  since it was working *more-or-less* before your touched it..
                  go back over your work..
                  unplug/plug all harnesses..
                  did you reset any error codes?
