skewing at duplex inverter (Nash 620d)
  • Richariri
    • Dec 2013
    • 163
    [Jamming] skewing at duplex inverter (Nash 620d)
    Ok I'm stumped, the office machine is jamming at the duplex inverter (jam code 125) when I clear the jam i've noticed the paper has caught on the back edge and has skewed...
    ...I CANNOT find what it is skewing off... has anyone experienced fault before?
    I've tested the drive to the rollers with output check and all seems ok, I've cleaned the sensors although I don't think it's a sensor problem.
    the paper is premium quality stacked well and not overloaded
    this jam occurs on the very first duplex page everytime, and has never jammed simplex.
    suggestions anyone?
  • Richariri
    • Dec 2013
    • 163
    Re: skewing at duplex inverter (Nash 620d)
    ok, my bad.
    tiniest bit of loose paper causing the paper to go off track.
    didn't see it until I pulled the fuser out.
    all good now
    • JustManuals
      • Jan 2006
      • 9838
      ​Another satisfied customer.
