mpc 4000 Coated Paper
  • pLatik
    • 169
    Hi,
    are any chance of print Coated Paper: glossy in duplex mode?
    thanks
  • rthonpm
    • Aug 2007
    • 2849
    Re: mpc 4000 Coated Paper
    Very small: the very selection of glossy paper as a fuser setting will probably cancel the ability to duplex. Trying to do a manual duplex would probably work, but you'd be running processed paper through the machine for a second time so all bets as to end quality would be in the air.
    • qbert69
      • Mar 2013
      • 1152
      Glossy paper is total crap!
      Why?...Glossy paper is made with CLAY!....It requires extra heat to bond the toner to the surface, it also holds/retains the heat in the paper...once paper starts stacking, and holding the heat, you will have pages that stick together and toner that will offset to touching pages...I have had this happen on HP and Ricoh printers doing color pages.
      Best bet is to run a matte finish heavy paper with high brightness to eliminate show-through!
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • pLatik
        • 169
        • TonerMunkeh
          Professional Moron
          • 3865
          Hit it.
          • Zaxxon
            • 608
            Often we have the seller to blame for this, "Yes it will sure do that" is the most common seller reply.
            Please start you post with brand, model, problem.
            • turbojetboy
              • Aug 2009
              • 279
              Originally posted by pLatik
              Hi,
              thanks
              If you do manage to find a work around, you had better be ready for the non stop calls you are about to be in for. Things like the slightest little mark or deletion, slightest mis registration, jamming at the fuser and worn fuser parts. next they will want the "edge to edge" printing feature (yes it's in the driver) "turned on". Welcome to a world of pain and loss making on this machine
              I might sound a bit negative here, but I have been through all this too many times.
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                Wrong machine for the application !!!!!!!!!!!!!!!!!headaches and pain if you don't nip this in the bud NOW !!!! or upgrade them to a Pro C901, LOL
                Mystic Crystal Revelations
                • pLatik
                  • 169
                  the problem is that the client have a konica c253 (sell by our company) who print in that paper with a good strong quality and without any modification.
                  but if there is nothing to do, patience. thanks to all
                    • 37375
                    When it comes to photo glossy paper, check the lable on the paper pack. If it is labled for "Ink Jet" do not use it on a laser machine. The glossy coating can stick to the fuser belt or at least bubble even in a Production speed machine. If it is labled for laser printers, a 40 page per minute or faster should be able to do duplex. I would still checl with the paper supplier. If they say yes, get it in writing.
                    • Eric1968
                      • 2458
                      Don't adjust the fuser settings, it will not help. Like slimslob mentioned, don't use (glossy) inkjet paper, it will ruin the fusing unit. The MP C4000 is not the same as a printing press...
