Ricoh Pro 906EX NCR rollers
  • freginold
    • Sep 2010
    • 102
    I know Ricoh came out with special rollers for feeding NCR paper on the big machines, but I can only find part #s for NCR rollers for the LCT. Does anyone know the part #s for NCR rollers for trays 1-3 for the Pro 906 or 907 series?
    Config page instructions for copiers, printers, & fax machines
  • slot
    • Jul 2008
    • 341
    Re: Ricoh Pro 906EX NCR rollers
    I have only seen rollers for the bypass but you could try the roller for the new baron mp8110 they are for thicker paper and look like the ones used on the mpc7001 bypass
    • watson
      • Sep 2009
      • 64
      The LCT is the only place I've been able to get NCR to feed. I don't think you'll have any luck feeding NCR out of trays 1-3 with any kind of tire.
        • 37453
        If you check the part number on the NCR feed rollers, you will find that they are the 300K feed rollers for the old LCT's. Also, they are actually more for slick surface than NCR. I have a customer with a Pro135EX who does NSR quite freequently using the regular rollers. For NCR, there is an additional guide bracket that you have to use to prevent jamming in the tray.
        • freginold
          • Sep 2010
          • 102
          Thanks! I ordered that guide piece, hoping it comes in today.
