After fixing a problem that required removing the laser to remove the laser seals (one came loose and partially blocked the laser for the Magenta PCU), I have a new problem.
The Yellow is shifted to the right by about 1 mm or 3/32 of an inch. I.e. orange letters have a yellow shadow on the right side of the red and pictures are blurry.
Drawing a line down the left margin of the page, the yellow is clearly out of line to the right, i.e. the other colors are not off to the left.
I am assuming there is a service adjustment and I have the Service Manual, but I do not understand how I correct this. It may just be the terminology in the manual, but I am reluctant to play with all the settings until I am sure I know which one.
Also, does the printer have a good internal test pattern for checking alignment issues?
Thank you,
John
Thank you,
John
