Firmware-the never ending story
  • Zeldaman
    • Mar 2011
    • 946
  • Eric1968
    • 2458
    Re: Firmware-the never ending story
    Ricoh machines don't like that SD-Cards > 1GB. I only update firmware when it solves a problem or when it adds functionality to the machine. I have lots of machines running with the first frimware versions.
    Don't try to repair a good working machine.
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      All you say is true eric1968, but our customers like the "older" Ricoh-systems. Since the most of them change to W7 now we have to update . Since the MPC 2800, we use 2GB-cards without problems.
      Greetings...
      • Eric1968
        • 2458
        Originally posted by Zeldaman
        Hi there!
        Greetings...
        Well updating the NIC-firmware to make the machine work with Windows 7 is of course a good reason. I use the language SD-Cards of the SP5200 machines to update firmware. They are 512 MB (I think...), and I never used anything > 1GB.
        • slot
          • 341
          if this is such a problem why not use the remote firmware I know I use an sd card (old habits die hard) all the time but with a laptop it can be faster
          are we all just set in our old ways
          • Ricohguy
            • Sep 2012
            • 48
            Unless you have figured out a way to do batch firmware updates with remote, remote firmware is MUCH slower.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Bingo !!! no batch updates this way
              Mystic Crystal Revelations
              • Iowatech
                Not a service manager
                • 3930
                If you take in old machines for trade in, harvest the option SD cards from those machines, delete the files from the cards and use them for firmware upgrades. That's what I use. Works great, and not that expensive.
                You'll find it convenient to have more than one SD card then, though.
