Ricoh model printer,scanner without pc to usb
  • tecnomarco
    • Jul 2011
    • 214
    Greetings all, I need to know preferably a digital multifunction RICOH, or KYOCERA, MINOLTA printing and scanning documents directly to pdf, word, jpg, inserting the USB key on the keyboard without the help of the PC thanks to the 'help
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh model printer,scanner without pc to usb
    For Ricoh it varies; but generally any model later than, and including, MPC2050 (with the media SP turned on). The smaller models may require an optional HDD.
    • tecnomarco
      • Jul 2011
      • 214
      Re: for ruben
      Thanks Ruben, especially trade used machines overhauled, now I have these models MP C3000, MP C4500 and do not have the USB input on the console, if you can kindly tell me which models Ricoh can print and scan directly to USB without a PC, speed 30 -35-40 minute copies, I repeat my problem is that my client wants to insert the uSB key and print files such as PDF, JPG, Word, and also use the scanner to store on usb stick and send via email, thanks
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Neither of those models will support media printing, and you will never be able to print Word documents this way; it is only images and PDF files. Direct media printing is always done from the rear of the machine on the older models, and from the console, or just next to it, on the newer models.
