ricoh c6000 print scan issue
  • redneckstylin
    • Sep 2011
    • 173
    long story short upgraded firmware on this beast and now it nags more than my wife....
    I have lost print scan feature
    and I try loading the print scan firmware and it stalls on the firmware
    any help be greatly appreciated
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: ricoh c6000 print scan issue
    Why was the firmware updated? Try doing a memory clear on NCS, Printer and Scanner Applications; 5801-011, -008 and -009. Take a note of the network connection settings before, then try another firmware update.
    • redneckstylin
      • Sep 2011
      • 173
      well it was throwing a sc code for fusing unit so figured hey while im at it ill think ahead and do some firmware ya never know seen weird things happen well now it kicked me in the ass
      • redneckstylin
        • Sep 2011
        • 173
        memory clear was successful
        will not take any firmware......
        • johnyb
          • Feb 2011
          • 167
          I have had this issue, I think it may be because of a big leap in firmware levels.
          Roll back if possible and step the versions up one at a time...takes a while, you may have to remove print scan whilst doing the rest.....
          Good luck!
          • redneckstylin
            • Sep 2011
            • 173
            ok so as soon as I try doing any firmware old or new it just beeps and tells me to screw off pretty much
            • mikadonovan
              • May 2008
              • 2931
              You might have had a corrupt firmware download (it happens occasionally). Redownload the firmware, and check also to see if that level of firmware requires any other firmware modules to be installed at the same time to function.
              NEVER ASSUME ANYTHING
              • okirob
                • Feb 2012
                • 26
                you can also try doing a remote update
                • redneckstylin
                  • Sep 2011
                  • 173
                  corrupt firmare took out the p/s function had to order whole new p/s card
