problem with scan to email(MPC4500)
  • ak01
    • Jan 2008
    • 14
    hi guys,i hav encounter this problem and still looking for the solution..got problem when i try scan to email,scan status will appear as error.i hav check the connection test with smtp server from the mc and it was succesful and fyi the smtp authentication always turn off(already verify with server admin)..i also try to ping the smtp ip from other pc and there was a reply..
  • tonyd
    email
    Are you trying to scan to an internal email address. If not you need to add the IP address of the machine to the Relay restrictions on the server to allow it to email externally
    Tony
    • ZeusGT
      • 271
      Are you using Outlook, Lotus notes or something else as your email client? What kind of email server are you using i.e... exchange, Linux email server?? There are a lot of tricks to these copiers for different email servers.
      CompTia A+ Certified
      CompTia Net+ Certified
      CompTia Server+ Certified
      CompTia Project+ Certified
      OP Scanshare Certified
      • nobody-here
        • Mar 2008
        • 237
        Your SMTP server is "IP Number" or Name resolved?... check your DNS
        29 rouge unpair manque.... cous cous....
        • fausto1981
          IT Technician
          • Dec 2007
          • 146
          if none of the above work, try a telnet session
          open the command promp -
          - Type telnet servername 25
          - helo servername
          - mail from: machine_email_address@customers_domain.com
          - rcpt to: intername_e-mail_address@customers_domain.com
          -data - type your message - enter - enter - .
          quit or exit to close.
          • ps/pcl
            TECH SPECIALIST
            • Jun 2008
            • 35
            hi ,i faced this problem few time ago
            after configuration restart the machine
            and try scanning it
            • pspahr
              Toner Schlep
              • May 2008
              • 227
              9 times out of 10 there is a dns issue. Make sure their dns is correct in the machine. Easiest way to obtain that info is at a PC-->Start-->run-->type "cmd" (without quotes) and click/press enter. At command line type "ipconfig/ all" without qoutes. Pull the dns from the second to last line of info and enter that into the Ricoh.
              If you have the info available let us know what type network enviroment the customer has and never automatically take what the customers IT dept. as gospel.
              VectorLinux---Check it out!
