Ricoh Pro C901 Booklet Maker BK5010 Connection Problems
  • jmandassociates
    • Sep 2008
    • 186
    I am working on a Ricoh Pro C901 that we just moved to a new location. It was supposedly working fine at the previous location. Now we set it up again it works fine with just the SR5000 finisher, but when we connect and dock the BK5010 with CF5010, TR5010, and BF5010 the paper goes through the SR5000 finisher and out but just sits in the input of the BK5010. The BK5010 doesn't seem to do anything. I disconnected the BK5010 with the other finishers and ran diagnostics and it didn't have any errors. Is there anywhere to check on the actual copier to make sure it is connecting and recognizing it.
    • 37560
    Re: Ricoh Pro C901 Booklet Maker BK5010 Connection Problems
    Are you getting a Jam code? With the BK 5010 connected to the finisher, lift the top of the BK 5010 and check the position of the upper entrance with respect to the mount screws and ends of the static on the upper exit assembly of the finisher. Contact can cause the upper exit assembly of the finisher to bind with the exit rollers not in contact. Paper stops about half way between the two. I have had this problem with a BK 5010e connected to a Pro 1107ex and the Jam code was 117.
    • Bantams
      • Jun 2012
      • 603
      Isn't there a little power button on the sr5000 for disconnecting the plockmatic like on the old bellinis?
      • jmandassociates
        • Sep 2008
        • 186
        The paper does stop half way between the 2 touching the rollers of the Booklet maker, but the exit assembly of the finisher isn't touching the roller on the booklet maker, and I am not getting any jam or error codes on the main machine or on the bk5010e. Also the rollers in the booklet maker are never even spinning. They do when I do the self test on the booklet maker in the service menu on there by itself. But when making a copy it doesn't seem to do anything. Is there any way to check on the C901 is the settings or service menu somewhere that the C901 s even recognizing and connecting to the BK5010e??
          • 37560
          If the C901 is properly showing the option for a booklet staple, the main connection is correct. One of the leads in the connection harness is the signal for the BK to turn on it's infeed motor. Check the point-to point to determine which lead and check it. I also think that there is a check point on one of the boards in the back of the BK where you can monitor that signal and manually key up the BK. If the signal there but the BK does not start it infeed, the problem is either the connection board or motor board on the BK.
          • jmandassociates
            • Sep 2008
            • 186
            When I only have the SR5000 finisher attached in the output options it shows Finisher Upper Tray and Finisher Shift Tray. When we connect the BK the only option is Finisher Upper Tray. This is in the System Settings Output Printer. This is the printer only C901 so I don't see all the same options and settings as on the copier version with an ADF. Also we took the back cover off and the LED lights on the BK5010 Copier Interface PCB and the D1 Connection detect LED never comes on, D9 start signal from copier, and D10-12 all never come on.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Production
              Booklet
              Finisher
              Booklet Finisher
              BK5010e 404305 C (B234)
              Cover Feeder Cover Feeder
              CF5010e 412102 C (B234)
              Trimmer Unit Trimmer Unit
              TR5010e 404299 C (B234)
              Book Fold
              Unit
              Book Fold Unit
              BF5010e 404300 C (B234)
              Are these the accessories you've installed? The PSG lists "e" models only.
              Mystic Crystal Revelations
              • jmandassociates
                • Sep 2008
                • 186
                Originally posted by Tonerbomb
                Production
                Booklet
                Finisher
                Booklet Finisher
                Book Fold
                Unit
                Book Fold Unit
                Here's everything installed
                BK5010e Booklet Maker
                CF5010e Cover Feeder
                TR5010e Trimmer
                BF5010e Book Folder
                RT5050 LCIT
                EFI Fiery E-41
                SR5000 Finisher
                  • 37560
                  [ATTACH=CONFIG]23624[/ATTACH][ATTACH=CONFIG]23625[/ATTACH]
                  The option for selecting type of stapling should be in the "Printing Preferences" of the print driver.
                  Also check the printer selection setting on the BK.
                  • jmandassociates
                    • Sep 2008
                    • 186
                    We tested the cable from the finisher to the BK for continuity and it tested fine. We sent the copier interface board from the BK and the main board from the finisher to get repaired and both tested fine. I just can't figure out why none of the status LEDs on the copier interface board in the BK are coming on at all.
                    • slot
                      • Jul 2008
                      • 341
                      I have seen this on a pro 907 ect look at the latch the one you kick to disengage the plotmatic is the arm being pushed all the way home so it makes the sensor under the raised plate .. If not the plotmatic isn't register try moving it closer to the upstream device. also this will sound mad add a white sticky lable too the arm as it enters the sensor this gives it a better chance of seeing the arm its this arm and sensor that tells the copier the plotmatic is set this has always been the fix for me and it make sense if you have move to a new location the set up of the units has to be just right
                      • jmandassociates
                        • Sep 2008
                        • 186
                        I actually just checked that yesterday and the lock is engaging and the arm is going in under the sensor. I even went into the service mode on the BK5010 and did a sensor check for that docking sensor it was at 0 when the BK was pulled away and 1 when it was docked so the sensor is working.
                        • Moza
                          • 232
                          So if the paper just sits in the infeed of the booklet maker its for one of two reasons either it hasn't detected the paper going in or it doesn't know what to do with it going out. Check connection to all peripherals and make sure the machine recognises them too also can you run the booklet maker offline
                            • 37560
                            With the Plockmatic undocked can you manually feed documents sets and have it staple and fold properly?
                            • Vollegaaz
                              • 73
                              Well, that should be checked first, so is the BK5010 working offline/stand alone?
