Has anybody figured this out yet??? I can't seem to get SMB scanning to Vista to work... Thanks
SMB scan to folder Vista.....
Hello, for Lanier LD024c you can't directly do Scan to Folder (SMB) you need to use Scanrouter V2 Lite and a PC running as delivery server.
I think that Ld238c would have SMB service installed into, try configure all the Network parameters, remember to get "Read and Write rights" to put files to the folder you should write to.
Regards29 rouge unpair manque.... cous cous....Comment
Here's a link for smb scanning to folder I posted earlier:
http://www.copytechnet.com/forums/ko...smb-vista.html
Good luck!Mystic Crystal RevelationsComment
I have some files my regional rep gave me on that stuff. Should have everything you need. Want a copy? Send my your email. Windows login and password is very important. Gotta make an exception in your firewall also. Let me know what you decide.GingerComment
With the right Firmware and the settings configured properly I never had a problem with Vista ever. Just when it first came out but once the firmware was released everything is OK.
Check this link it shows you a video on how to share a folder on Vista
http://windowshelp.microsoft.com/Windows/en-US/help/9d98dcbd-853a-4235-82e5-00e8e468dec21033.mspx
Also please check the attachedment there is a couple of things in there that you have to make sure are setup correctlyComment
