which is enter key on RICHO AFICIO MP2000L
  • gateway.vly@gmail.com
    • Dec 2007
    • 52
    Hai
    can anyone know which is the enter key richo aficio mp2000l
    thanks
  • skynetto
    • Sep 2012
    • 257
    Re: which is enter key on RICHO AFICIO MP2000L
    36837. (Enter in T9 mode). Or you can press # if you like.
      • Dec 2007
      • 52
      Originally posted by skynetto
      36837. (enter in t9 mode). Or you can press # if you like.
      thanks for your quick response actually i want enter ssp mode in the service manual says press the enter key and hold it down
      the machine not print from pc i can able to login wia network ip address
      my pc have windows 7 64 bit
      • Elmo
        • Feb 2010
        • 541
        i think you are looking for the round redish cancel stop button
        the MP2000L is the lite version of this model you must use the correct driver
        I Used To Live To Fix Things Now i Fix Things To Live
        • Athlontini
          • Jun 2012
          • 269
          He's talking about SSP Mode, which is where you hold down the # key before hitting System SP to unlock the SP8xxx and 9xxx sections.
          So yes, enter is #.
          • Llama God
            • Mar 2009
            • 1353
            If you can't print then special service mode isn't going to help you. Fundamental troubleshooting will. Check the port in the printer driver.
